JobDismantler-Assemblejob
mcolmenero
Post by mcolmenero »
I try to make a flow than clean temporary mac's files.
I put inside a folder or structure folders inside files.
Like this example
folder1:
.ds_store (temporary mac's file)
._dile.indd (temporary mac's file)
file.indd,
file2.indd
folder2:
file3.pdf
file4.xls
I want to get up this result:
folder1:
file.zip (file.indd and file2.indd)
folder2.zip (this if is posible else together in one file)
First I use job dismantler:
-Subfolder: 99
-Attach hierarchy info: yes
-Add job folder name: yes
-Include subfolder level: 1
-Save top subfolders: yes
and in assemble job put:
-Scheme: ungroup job
-Private data key: ungroup
-Numbers of file: automatic
-Merge data: yes
-Job Folder name: single line...[Job.Hierarchy:Index=1]
-Strip unique name: yes
My problem is that when assemble job give me all file without the folder1, delete the temporary files.
I don´t know what i make bad. Could you help me please? or if you have other posibility to keep off temporary mac´s files, perhaps it´s valid for me.
Thanks, best regards.
Miguel
TOP CONTRIBUTOR
Post by dkelly »
Hello, try this simple script. It monitors a directory and deletes the Mac resource files. There are no input or output connections.
// Cleanup Mac resource files
// Written by Dwight Kelly <dkelly@apago.com>
// Copyright 2012 by Apago, Inc. -- All Rights Reserved
const cLogInfo = 1;
const cLogError = 3;
var interval = s.getPropertyValue("interval");
if (interval > 0)
s.setTimerInterval(interval);
var theDirName = s.getPropertyValue("theDirName");
var theDir = new Dir(theDirName);
if (theDir.exists) {
var entries = theDir.entryList("*.*", Dir.All|Dir.System|Dir.Hidden, Dir.Unsorted);
for (var i = 0; i < entries.length; i++) {
var fileName = entries;
if (fileName == ".DS_Store" || fileName.left(2) == "._") {
var theFile = new File(theDirName + "/" + fileName);
s.log(cLogInfo, "Deleting " + fileName);
theFile.remove();
} else s.log(cLogError, "Error accessing directory: " + theDirName);
Dwight Kelly
Apago, Inc.
dkelly@apago.com
mcolmenero
Hi Dwight Kelly,
sorry for my late answer. I have been on hollidays.
Thanks for your help, but I put a structure folders. And my problem is when It assemblejob is not do good. It no assembles like the same I put inside.
And your script is not looking for all structure.
Thanks.
Best regards
mcolmenero
hi Dwight,
But what need i to write with s.getPropertyValue("theDirName") and s.getPropertyValue("interval")? I need to define these variables?
Because I can´t put swich on the flow.
I make a flow with:
folder in - your script - folder out
The log flow says me "28/06/2012 12:55:59,Error,SwitchScript0,New flow,SwitchScript0,008UW,Grupo Mejora,Requested property is not defined: 'theDirName'; trying to use default value"
I put inside folder structure folder and files, but no go on. What need i to go on?
TOP CONTRIBUTOR
Post by dkelly »
You either need to add properties for "theDirName" and "interval" in Scripter or set them to a fixed value in the script.
var interval = 86400; // every 24 hours
var theDirName = "/Volumes/BigServer/Path/To/Cleanup";
