I have submitted a feature request to remove the shortcut key to delete a flow (on Mac). I feel that since Command-W has always been used to close windows on all other Mac application, it is unproductive to have it delete a flow in Switch. I submitted a feature request to Enfocus was to remove the shortcut key to delete a flow, allowing flows to only be deleted by explicitly choosing to do so from the menu. The response was that if they make that change, it would affect all users who are already familiar with the shortcut key.
So, I am asking the community... do you often use Command-W to delete a flow? Would it affect your workflow if it was removed and had to use the menu to delete flows? Would it be better to have it as a different shortcut (e.g. Command-DELETE)?
Thank you for your input!
Delete flow shortcut key (Mac)
r.zegwaard
Re: Delete flow shortcut key (Mac)
Never used command-w to delete a flow. Didn't even realize that this shortcut existed to delete flows....
Enfocus says they will make the necessary changes on an upcoming release.
