Problem using Hold element
mrkkrai
Post by mrkkrai »
Hi:
I'm fetching approximately 20-25 PDFs from FTP and time interval between files is 2-3 minutes. I have set FTP check every 5 minutes and used "Hold" element (Delay scheme; 30 minutes; Cyclic) to wait until all PDFs fetched. After getting all PDFs, they are merging in a single PDF using "Merge PDF" element.
Here is the problem. I'm getting multiple PDFs containing few pages instead of single merged PDF, eg.
File1.pdf (containing page no. 1-3)
File2.pdf (containing page no. 4-10)
File3.pdf (containing page no. 11-16)
... and so on.
Please help.
sander
Re: Problem using Hold element
Post by sander »
You need a Assemble Job before Merge PDF. Do you have one? :)
mrkkrai
Post by mrkkrai »
No. Should I use "Assemble job" before "Hold job" element?
sander
Post by sander »
Correct:
"Merge PDF is a processor that produces a single PDF file containing all of the pages provided by the PDF files in the incoming job folder."
You can use a sort before to order your files:
mrkkrai
Post by mrkkrai »
It's not working. I'm doing something wrong I guess.
https://pasteboard.co/Hv0AHq4.png
For Assemble job, Scheme is Arbitrary files after 2 minutes; Orphan timeout is 30 minutes.
While for Hold job, Delay Scheme for 30 minutes Cyclic.
sander
Post by sander »
You don’t need hold job, just assemble job with correct timeout settings.
