How to check for resolution
hep@harwill.net
Post by hep@harwill.net »
Is there an action list that will allow to check for resolution of all objects within a pdf?
LasseThid
Re: How to check for resolution
Post by LasseThid »
I don't know if you can do it with an action list, but a preflight profile can do it for sure.
The attached preflight profile will list the resolution of any image with a resolution below 1500 dpi.
Worst case just create a new Preflight profile, go to Images and select Resolution of. Set image type and resolution, then under General - Preflight report check the Images check box and you will get a preflight report when you run the preflight profile.
Check resolution of images.ppp.zip
(6.05 KiB) Downloaded 1177 times
Terkelsen
Post by Terkelsen »
Hmm, how about the action "Check resolution"? ;)
