Pitstop Server Configurator - Concurrency
ArielRauch
Post by ArielRauch »
I have several flows that have several Pitstop interventions.
I noticed that jobs are waiting for the first to finish before progressing. I entered the Pitstop server console and got confirmed that indeed it is processing one at a time.
Please advice,
Ariel
Check the number of concurrent processing setting in the PitStop Server preferences.
ArielRauch
Checked it. It is set to 13.
Then check the Switch Preferences (Processing). The maximum value that you can specify there depends on the performance module you have. The Core Module allows 4 concurrent processes. Note that these 4 are shared with other processes as well, so it may very well be that only 1 PitStop Server instance is running because the other 3 channels are taken up by other activities. It is impossible to predict what the exact behavior will be. If you want to test it, you should do that with nothing else running except a flow that only uses PitStop Server. I am sure you will see more than 1 job being processed by PitStop Server at the same time.
danielb
Re: Pitstop Server Configurator - Concurrency
Post by danielb »
This seems like a not configurable issue, in 2018 this is still the case: viewtopic.php?f=11&t=2518
abailescollins
Post by abailescollins »
Best thing will be to contact Enfocus support.
You'll get an answer faster, and it will be logged and tracked.
They can also take a look at your system if necessary.
abc@imposition.com
