Removing the extension when using the %Current Document Name%
dreimer
Post by dreimer »
I want to create an action to add a code to my document based on the filename. I have done this but wanted to know if there is a way to remove the extension (".pdf").
TIA
Stephen_A_Marsh
Re: Removing the extension when using the %Current Document Name%
Post by Stephen_A_Marsh »
Not that I am aware of.
If we could add a regular expression, the following should do the trick:
Having the ability to create our own text variables or to modify standard text variables would be nice.
dreimer
Post by dreimer »
Could this be done using Switch?
Terkelsen
Post by Terkelsen »
Yes it can be done in a combination of PitStop Server and Switch. Create a Variable set in PitStop Server with a single variable of the type Constant->Text.
In the PitStop Configurator in Switch change that type to "Text with variables" and use [Job.NameProper] as the variable value.
