Remove cropmarks
babathemacman
Remove cropmarks
Post by babathemacman »
I have received a pdf file supplier and the crop marks must be removed and new places must be removed. I manage to remove the outer cuts, but not the inner ones. I want to place new format on the format of the second crop marks and then let our flow go for other operations. I want to remove the crop marks because we get files that are all different. Do you have any idea how I can solve this problem?
Luisman-Meliesie RK 19042959_Pagina_2.jpg (174.05 KiB) Viewed 11803 times
bens
Re: Remove cropmarks
Post by bens »
Did you try running the action to remove crop mark twice? The first time should remove the outer marks, and hopefully the second time can remove the inner marks.
babathemacman
I tried, but the second crop marks do not really see the file as crop marks so this does not work
RytisT
Post by RytisT »
Crop marks are supposed to be outside of the crop box I believe, I suppose crop box is set according to outter crop marks? Therefore inner crop marks are inside the cropbox making them invisible to pitstop,
abailescollins
Post by abailescollins »
Can you upload a sample PDF file please or send it to me?
andrewb@enfocus.com
It's probable the inner set of marks are hand drawn, and not being detected.
I'd like to investigate.
abc@imposition.com
