Replace comma with a dot
schmitzdp
Re: Replace comma with a dot
Post by schmitzdp »
jan_suhr wrote: Tue Aug 24, 2021 1:27 pm You should be able to specify the variable as the string to replace the spaces in.
Do you have an example ? Because my results are always the same. :cry:
You have to use String Replace in the Private Data mode.
And to get the filename value in to a Private Data you have to set that Private Data value from the Metadata variable in the folder before the String Replace app.
Then in the String Replace app you select the Private Data key for the Data property.
In Strings you do your search and replace i.e. space=%20
After that your Private data value would have %20 in its filename.
Good luck
schmitzdp
Post by schmitzdp »
Thanks for your explanation. I have applied it and it works perfectly :D
