Switch Calculation/ Pitstop Variable Set
Chrissigge
Post by Chrissigge »
Hello, I hope the title is not too confusing.
Heres my problem:
with Pitstop im creating an rectangular shape and place it on my incoming PDF File,
the shape length should be calculated based on 2 values from the XML-File.
These values have a unknown length. Im saving the length values into hierarchy path.
I can read out each value:
First value
[Switch.Calculation:Expression="[Job.Hierarchy:Index="1"]+10.0"]
or second value
[Switch.Calculation:Expression="[Job.Hierarchy:Index="2"]+10.0"]
In order to create the rectangular shape in the correct size I need to know which of these values the longest one is.
An if else rule would be an easy option but i don't see the possibility to use this with variable sets....
Does anyone have an idea?
Re: Switch Calculation/ Pitstop Variable Set
Do you have the Switch scripting module? If so, this becomes quite easy: the variable to be used in PitStop would be of type "Script expression", and the code something like this (untested):
var value1 = job.getVariableAsNumber( "[Switch.Calculation:Expression=\"[Job.Hierarchy:Index=\"1\"]+10.0\"]" );
var value2 = job.getVariableAsNumber( "[Switch.Calculation:Expression=\"[Job.Hierarchy:Index=\"2\"]+10.0\"]" );
(value1 > value2) ? value1 : value2;
The result of this script expression is the largest value.
You can achieve the same result without the scripting module. A simple condition with variables applied to a connection will work.
You can create two outgoing connections. You will then set one outgoing connection with a connection with variable. As a parameter just enter this line ion first field :
[Switch.Calculation:Expression="[Job.Hierarchy:Index="1"]"]
and this one in second field :
[Switch.Calculation:Expression="[Job.Hierarchy:Index="2"]"]
For the operator choose greater (…or equals).
Then on the second connection choose all other jobs. Then you can do further processing.
HTH,
Loic
http://www.ozalto.com
