Strange error using "Document Flow"
lombert
Post by lombert »
Hi All
I was making a "Document Flow" and it came up in my Safari and everything looks good. Saving it to a Web Archive and opens that in the same Safari and it looks like this:
I try to open it on one other computer and the same result. Is I the only one having this? :)
Between jobs!
Terkelsen
Re: Strange error using "Document Flow"
Post by Terkelsen »
I can't say that you are the only one having this problem, but I've used this feature a lot and never came across that problem.
lombert
Post by lombert »
Terkelsen wrote:I can't say that you are the only one having this problem, but I've used this feature a lot and never came across that problem.
Good to knew. Then I will continue here to see what can be wrong with my settings.
Thanks!
Between jobs!
lombert
Post by lombert »
It works if I change to Chrome instead of Safari. Then I can open it in Safari and it looks right.
Between jobs!
