variable text into PDF
abonsey
Post by abonsey »
Whats the best way of adding the PDF file name to the PDF just outside the bleed box on a given page??
Re: variable text into PDF
If you have PitStop, you can use the action "Add object". Select the variable "%Current Document Name% and either position it relative to the bleed box with a negative offset, or relative to a larger box (e.g. the media box) with a nonnegative offset.
abonsey
Post by abonsey »
Thanks. Works really well.
Obvious when you know how!
