Pickup filename in submit point (or later)
I am setting up a flow where the customer submit files from PitStop connect to a Switch submit point.
At the end of the flow some emails are sent. However the Mail send pickup the filename of the report since that triggers the mail.
I have tried to find any varible for the jobs filename but haven't found any that works.
The submit point has some META fields that the submitter has to fill out and all that Meta data is then used at the end of the flow for sorting and email.
Saw in another thread some discussions about this and there was a non-working link to an example that should solve this.
Jan
jonasy
Post by jonasy »
I assume that the report is named Filename_Report.pdf?
Then you can use the following variable to get only Filename, it will strip the underscore and everything after it.
[Job.NameProper:Before=_]
Yes your assumption is correct.
Thanks for the tip, I was thinking that something like that would be the trick.
Jan
