Saxon XSLT v2.0 and multiple node XML data
abonsey
Post by abonsey »
Hi All,
Has anybody worked with the new Saxon configurator? I've a multiple node XML file that I'm looking to break into individual XML or csv files and I've looking for help or examples on how to do this within the new configurator.
Thanks for any help
abonsey
Re: Saxon XSLT v2.0 and multiple node XML data
Post by abonsey »
Hi All,
Nobody out there got any thoughts on the new XSLT v2.0 and working with nodes?
sander
Post by sander »
This month I'll upgrade to Switch 13 and want to achieve the same thing with the Saxon connector. At the moment I'm doing the same with Saxon via execute command.
Not really the reply you are looking for, but within a couple of weeks I probably have a useful reply :lol:
sander
Post by sander »
Just switched from Saxon via Execute Command to the official Saxon Configurator. My old situation can be seen here: http://forum.enfocus.com/viewtopic.php?f=12&t=1201
With the old situation I am running Saxon HE 9.6.0.4 Java Edition. With Enfocus writing "On Windows configurator searches for .Net version of the processor first and only in case nothing is found it searches for Java version." I decided to switch to the .Net installation. Version 9.7 is not available as .Net yet, so I got 9.6.0.8.
http://sourceforge.net/projects/saxon/f ... on-HE/9.6/ (SaxonHE9-6-0-8N-setup.exe).
I only set the Stylesheet value in properties, and the output is exactly the same as my original setup.
So quite easy at this side. What's your issue at the moment?
Arthur
Post by Arthur »
Hey Sander - would you be so kind as to share how you have the stylesheet line setup with variables??
I was under impression this is where you link to the stylesheet, but I can see I was not right on this.
Pls ? ;)
KR
Arthur
sander
Post by sander »
True, this is where you link to the stylesheet :)
D:\Scripts\Saxon\[Job.JobState].xsl
You can have different stylesheets that you link with variables. The variable is the filename of the stylesheet.
