Is PitStop able to read a JDF exported from Heidelberg Signastation?
massfisc
Post by massfisc »
Hello everybody,
i was wondering if PitStop Pro is able to help me interpreting a JDF and all related resources generated by PrinectSignaStation 4.5.40 (Build 0183.2)
My goal is to read the JDF and print the related content using a efi Fiery DFE. I expect the signature described in the JDF will be interpretated to print the PDF either with the correct pagination order or with the correct imposition applied during the printing process.
For your reference the file i've go to print is available at following link : https://www.dropbox.com/s/u8zz4js4czf03 ... f.zip?dl=0
Many thanks for any advise
Re: Is PitStop able to read a JDF exported from Heidelberg Signastation?
PitStop Pro is not the right tool for this - it's an interactive PDF editing tool. What you want is an automation tool that can handle JDF - which sounds like a good fit for Enfocus Switch.
Have a look at the product page at https://www.enfocus.com/en/products/switch , and in particular the JDF example at http://www.enfocus.com/manuals/Extra/Sw ... onjdf.html .
Ben
massfisc
Post by massfisc »
Many thanks Ben
i'll check it.
