Connect ALL User Name In Switch
rgpepper
Post by rgpepper »
When creating a connector with Connect ALL the only way a user name comes through into Switch is when you enter a user name and password (and select "Use Specified Credentials Above" when creating the connector) since that's the only way you can even specify WHICH submit point to use (I also posted a more Connect-centric post in the Connect forum here highlighting the same scenario). So I'm prompting the Connector user for a user name only in a metadata field, what I want to do in the Switch flow is have the contents of _this_ metadata field become the user name as far as Switch is concerned, not the user name that the connector supplies at the login/submit point.
