Copy file to folder-script?
wolle
Post by wolle »
Does anyone have a script - or know how to write it - that takes an incoming job, if it's a file, and copies it to a defined folder (arg1 as choose folder) and then lets the original file pass through.
Actually I need to copy to a networkfolder, and it can't be the normal Switch-method of moving files because that interferes with the hotfolder I'm moving to.
Anyone?
Thanks!
foxpalace
Post by foxpalace »
here is a example - you had to modify it, but it should show the way
var pfad = job.getPath()+"/Bilder/";
var myDirectory = new Dir(pfad);
var source = myDirectory.entryList("*.jpg", Dir.Files, Dir.Name);
for (var i = 0; i < source.length; i++)
var source1 = new String(source);
var neuName = source1.substring(0,4);
s.copy(pfad+source,pfad+neuName+"-bla.jpg");
