Injecting files using a Script_SOLVED
victor Lukenga
Post by victor Lukenga »
Im trying to inject files via my metadatas I have some issues
when I use the built-in inject tool I can import only the first file (I don't know if my XML is well writed ) when I choose the "files" node switch don't seem to read through the entire node
	Xml:
		<files>
			<file>
				<path>C:/Users/flprint-switch/Desktop/checker/ORDxxxxxxx/ORDxxxx/docs/xxxxx1.pdf</path>
				<path>C:/Users/flprint-switch/Desktop/checker/ORDxxxxxxx/ORDxxxx/docs/xxxxx2.pdf</path>
			</file>
		</files>
That's why I turned myself to scripting:
var dataset = job.getDataset('Xml');
//var path = dataset.evalToString('/order/files');
var dummyPath =( 'C:/Users/flprint-switch/Desktop/checker/ORDxxxxxxxx/ORxxxxxxx/docs/xxxxx1.pdf'); // for testing
job.sendToSingle(dummyPath);
The issues are :
the injected file is cleared from his original location(we have to keep the customers files )
the original name and extention are replaced or disapear
Only one file is imported
I can figure this out hope you will help me :)
Best regards :geek:
Last edited by victor Lukenga on Thu Mar 24, 2016 9:50 am, edited 2 times in total.
sander
Re: /!\ Injecting files using a Scripting
Post by sander »
You can't loop through nodes in Switch. Do you generate the XML by yourself?
Than the easiest approach is to create one XML for each file, which you can easily use with inject job.
      <files>
         <file>
         </file>
      </files>
victor Lukenga
Hi , thank you to take time to answer I really appreciate it
these Xmls are generated by a home made app
one xml per file is a bit complicated, cause all files contained in the "docs" folder are part of one order : we may have e.g 2 files for one business card
(fileRecto.pdf fileVerso.pdf)
the best way for me will be to loop through "files" node. I've tried and spend few hours to find a solution : answer is close to me but where :)
sander
Post by sander »
I used to do it this way, without scripting: http://forum.enfocus.com/viewtopic.php?f=12&t=1201
Since Switch 13 I upgraded to the Saxon configurator: http://forum.enfocus.com/viewtopic.php?f=12&t=1237
So it's already done without scripting. Keep it simple ;)
victor Lukenga
Yes this is my keyword too "keep it simple"
Ive just tried to run the saxon configurator but it return this
Flow validation error: The application is not available on Switch Server
I also donwload the version you provided on you post
I guess that saxon is open source ?
sander
Post by sander »
Running on Windows too?
Did you restart Switch / search for applications?
And yes, it's open source.
victor Lukenga
Yes I'm on windows
I unistall /reinstall it : Strange I keep have the same error :/
sander
Post by sander »
My Switch server is running on Windows Server 2012 R2 with only .NET Framework 4.5 installed, no 3.5 or earlier versions.
4.5 is not installed by default, do you have it?
victor Lukenga
[quote="sander"]My Switch server is running on Windows Server 2012 R2 with only .NET Framework 4.5 installed, no 3.5 or earlier versions.
Edit : I rebooted my machine : the configurator is now working
victor Lukenga
I wondered if evalToNodes can be suitable for my needs ?
var xml = new Document(dataset);
var node = xml.evalToNodes('/order/files/file');
if(dataset != null){
	for (var i=0; i < node.length; i++) {
		var myNode = node.getItem(i);
    	var files = myNode.evalToString(".");
		job.log(2, "files are "+theNode.evalToString("."));
		job.sendToSingle();}
}else{}
sander
Post by sander »
Yes this can be done, however I personally haven't done this yet. On the list to figure out later, little busy :)
But I'm sure some other more experienced scripting forum members can help you out.
Curious, did you get it to work with the Saxon transform?
victor Lukenga
thank you for your answer :)
I tried to play with Saxon but honestly I don't have experience in XSLT so I didn't understand how to setup Saxon.
sander
Post by sander »
Based on your given XML example I would do this ;)
Configure Saxon like this;
With this as content of your victor.xsl:
<xsl:stylesheet version="2.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output indent="yes"/>
    <xsl:template match="/">
        <xsl:for-each select="files/file/path">
        	<xsl:variable name="InputFile" select="base-uri()"/>
			<xsl:variable name="OutputFile" select="tokenize($InputFile,'/')[last()]"/>
        	<xsl:variable name="OutputNoExt" select="substring-before($OutputFile,'.')"/>
	    	<xsl:result-document href="{$OutputNoExt}_{format-number(position(),'000')}.xml" method="xml">
			<xsl:copy-of select="current()"/>
            </xsl:result-document>
        </xsl:for-each>
    </xsl:template>
</xsl:stylesheet>
Your input XML...
<files>
	<file>
	</file>
</files>
... will result in this two output XML's:
jobname_001.xml
jobname_002.xml
Does that help?
victor Lukenga
that's great
Ill give a try this week end I will also give you a feedback
Once Again Thank you for your help !
victor Lukenga
Hi Sander,
Thanks a lot for your help! it works like a charm it was exaclty what I needed!! wonderful forum !! ;) :mrgreen: :mrgreen: :mrgreen: .
thank you again !
