Need help on creating Switch flow
mrkkrai
Post by mrkkrai »
I need help on creating Switch flow
I'm getting multiple zip files in input folder:
Zip files contain files like this:
I'm unarchiving and adding unique numbers (highlighted) as prefix to each job folder and InDesign file by "Rename job" like this:
Using "Set hierarchy path", job folders are arranged in "Production" folder date-wise (dd-mm-yy):
I create PDFs of InDesign files. PDFs move in a "hot folder" where a rip software converts them to TIFF and send back to Switch.
Bottlenecks:
1. Need to create a subfolder "[job_name]_softproof" inside job folder.
2. Need to move that TIFF file inside this subfolder.
Here's my flow:
I'm not using any XML/Metadata.
Thank you.
Terkelsen
Re: Need help on creating Switch flow
Post by Terkelsen »
When the tiff-file returns from your RIP you should add hierarchy path with three segments:
1. [Switch.Date:Format="dd-mm-yy",TimeZone="System"]
2. [Job.NameProper]
3. [Job.NameProper]_Softproof
That should be all, I guess, assuming that the tiff-file is returned on the same day as the other files are being archived :-)
mrkkrai
Post by mrkkrai »
My apologies to all for duplicate threads.
Please post your replies on following thread:
viewtopic.php?f=12&t=1392
Thank you.
