HP JDF Control - Unable to move asset to asset file Location
Posted: Fri Jun 17, 2016 8:40 am
Sometimes I got the error, "Unable to move asset to asset file Location: /Volumes/Jobs/jdf_assets. Job cannot continue" then using Enfocus Switch and HP Digital Front End JDF Control.
The file gets to the error-folder, and then I 'Retry flow' to resend the file it usual get away to the next location, but I think when the file goes the second time by the JDF control it will not test to download the pdf to the Asset-location, it just makes the jdf-file and continues.
Then the JDF gets to the SmartSream Production Pro Print Server it stals and waiting for the pdf. And there is looks like it tries to rip, but nothing happening..
Anyone having the same problem?
This is the log from Switch;
Then we tried to resend it;
#Plugin Resources directory: /Library/Application Support/Enfocus/Switch/11/scripted-plugins/com.enfocus.HP~Digital Front End JDF Control
#List of asset files is: 4686394_Stora Mällösa 32.pdf
#List of asset URLs is: FILE://hpro1-sm1/Jobs/jdf_assets/4686394_Stora Mällösa 32.pdf
#Temporary JDF ticket location will be: /Users/macproauto/Library/Application Support/SmartStream Configurators/JDF/4686394_Stora Mällösa 32.jdf
#File extension for Asset is pdf
#Default Media name Silk 150g 450x319 set
#Unable to move asset to asset file Location: /Volumes/Jobs/jdf_assets. Job cannot continue.
#Job '4686394_Stora Mällösa 32.pdf' was already failed; can't send failed job
#Job '_02AQ3_4686394_Stora Mällösa 32.pdf' was moved from folder '/Users/macproauto/Library/Application Support/Enfocus/Switch Server/backing/Webtop JDF New/automanaged/Folder 31' to the problem jobs folder. Reason: see previous log message(s)
#Job '/Users/macproauto/Library/Application Support/Enfocus/Switch Server/ProblemFiles/Webtop JDF New/_02AQ3_4686394_Stora Mällösa 32.pdf' was successfully moved to its original folder '/Users/macproauto/Library/Application Support/Enfocus/Switch Server/backing/Webtop JDF New/automanaged/Folder 31' for retry
#asset file has arrived at location: /Volumes/Jobs/jdf_assets/4686394_Stora Mällösa 32.pdf <- There is no file there!
#Job _02AQ3_4686394_Stora Mällösa 32.jdf was placed in folder Folder 10
