Sorting Jobs files based on Folder hierarchy
alkea
Post by alkea »
Hi Guys,
I'm looking to route files based on folder hierarchy from the original submitted jobs, for example my normal folder structure in a submitted job folder is:
Parent Folder
Customer files (subfolder level 1)
Output (subfolder Level 1) / Print (subfolder level 2)
Preview (subfolder Level 1)
I want to route the jobs in customer files to Folder 1, Output and its subfolders to Folder 2, and Preview to Folder 3.
I have tried to use the hierarchy info to achieve this using Conditions defined with Variables. However I continue to get all subfolders to all three folders. I have used " [job.hierarchy:Search="Output"], & [job.hierarchy:Segment= Output], & [job.hierarchy:Segment=0-6] with it equal to Output
Any ideas on if this is possible and using the hierarchy or will I need to disassemble the job and sort each folder layer as I work my way down?
Re: Sorting Jobs files based on Folder hierarchy
Indeed, you have to use "Job dismantler", but only up to the first level if you want to route the folders or to a higher level (99) if you want to route the individual files as jobs. "Job dismantler" lets you attach the hierarchy information as well if you need it for further routing.
