Edit Action Lists?
strido
Edit Action Lists?
Post by strido »
I'm just getting into a trial on PitStop Server 13 (coming from 3.5) - I was under the impression that you can edit and create custom action lists from the Server, as opposed to having to create them in PitStop Pro and then importing them into your hot folder workflow.
Is that not possible? I don't see any options for editing Action Lists...
Re: Edit Action Lists?
It is possible, but sadly not from within the Hot Folder Editor (this would be a nice feature!) In the menu, go to Window - Action Lists. This will bring up the Action List panel similar to PitStop Pro (the same shortcut even works in Pro and Server). Here you can create, edit, and manage your Action Lists.
