PitStop Server Node - where's my action lists?
strido
Post by strido »
I'm using Switch 13.1 and PitStop Server 13 on a trial.
I see that you can use multiple actions in the PitStop Server node, if you choose "Select Many From Library".
How do I add my own actions to this library?
lombert
Re: PitStop Server Node - where's my action lists?
Post by lombert »
You add them in PitstopServer. then you need to reload the PitstopServer configurator, the easy way is to that is to "search" for the configurator in the configurator-list..
Between jobs!
