I've looked for all over for the answer to this one, and can't seem get any search hits whatsoever.
Using the Acrobat Configurator (natively or with Javascript), or some other method, is there any way to save out a file using the options Reduced Size PDF or Optimized PDF? I'm trying to compress files down as small as possible so they can be emailed, but need the files to be under 10MB. Am I only able to use the Pitstop Server preflight files to "fix" resolution issues and such, or can I use the Acrobat features as if I was manually saving a file?
Thanks,
Joe
Saving a PDF as "Reduced Size PDF" or "Optimized" from Switch
Re: Saving a PDF as "Reduced Size PDF" or "Optimized" from Switch
I'd urge you not to do this. Nobody likes big attachments and its very easy to just link to an uploaded file with something like S3. viewtopic.php?f=12&t=1178&p=4019jochwat wrote: I'm trying to compress files down as small as possible so they can be emailed, but need the files to be under 10MB.
That said, there's a few ways to do what you're looking for. One of the best solutions is an app called PDFShrink: http://www.apagoinc.com/prod_home.php?prod_id=36 / https://www.pdfshrink.com/
You can also apply optimizations via PitStop in Switch with the "Optimization" option and also apply file reduction in action lists. We have an action list that reduces filesizes by using "Change image compression" and "Optimize document structure".
pdfToolbox also has some optimization features.
Hi Joe
We do this a lot with PitStop Server, there are various Actions you can use to get the size down.
Resolution, compression, colorspaces, attachments, metadata, document structure, all of these can effect the size and be removed or adjusted.
Alternatively take a look at the new Enfocus PDF Review module for Switch, it can be fully automated, sends an email with a URL so the customer is seeing the actual high res production file, plus you know they are opening it in a viewer that supports prepress (overprint/transparency/separation view etc).
If you'd like to know more drop me an email 'andrewb@enfocus.com'
