Monitoring amount of jobs processed in a specific flow or flowelement
mireille
Post by mireille »
Does anybody know a simple solution to monitor the amount of jobs processed in one or more workflows? And specify or sort them by a flow element?
With statistics I only get information about the time and not the amount of jobs.
But maybe I'm using it the wrong way.
Thanks in advance!
Greetings from Holland!!
Mireille
Re: Monitoring amount of jobs processed in a specific flow or flowelement
Statistics is indeed for doing a timing analysis, not for counting files.
Writing a script that you put in the beginning of your flows and that keeps a counter in a file is not that difficult. I remember that you followed a scripting training once :D
Any other method:
- reading the CSV log that you can set in the Switch Preferences
- reading the XML output of the messages also in the Preferences
- writing to a CSV log file with the Switch Logger app: https://appstore.enfocus.com/product/Switch_Logger
will involve something extra to give you a count. The easiest method I can think of is to open the CSV in Excel and to apply "Data - Filter". This will give you a filter for every column and when you select the values of the columns you want, you will see the number of matching records at the bottom.
mireille
Post by mireille »
Hi Freddy,
Thank you for the quick reaction!
I'm going to try your different options and build them in our flows.
Grts Mireille
