Hold Job on Name based
numnational
Post by numnational »
Hy all,
Here is my problem.
I put a pdf file in "IN" folder. He go directly in Folder 14 and i want he wait the second file who go in "Enfocus PDF2Image" and when the jepg is out in "Folder 14" they go in "OUT" folder together. But i want this with the same name of file, not a number...
https://www.dropbox.com/s/gaeex1la9tl0f ... 8.jpg?dl=0
Thanks...
sander
Re: Hold Job on Name based
Post by sander »
This can be achieved via different ways.
Based on your flow I would do this.
Most left Rename Job:
- Remember original name: Yes
Right Rename Job:
- Replace on Filename proper. Replace by: [Job.PrivateData:Key="Original",Before=".pdf"]
Assemble job:
- Scheme: Filename patterns
- Pattern 1: *.pdf
- Pattern 2: *.jpeg
numnational
Thanks for your answer.
I make this and it work perfectly as i want.
And it's most easy than your example because i don't need to have rename job.
In assemble Job
Scheme : Custom
Job identifier : Job Name proper
Number of files : 2
Job folder name : Job Name proper
sander
Post by sander »
Hmm, you are correct.
I noticed my jpg was named -1, -2 etc. due to multipage pdf :)
Good to hear you got it working!
