Sorting PSDs by file dimensions?
ERodgers
Post by ERodgers »
Hello all, I'm looking for a solution for sorting PSDs by the file's dimensions. I already have a flow in place with an XML Pickup that sorts PDFs based on it's dimensions. I'd like to implement this method using the XML pickup, but the only variable that I can choose that corresponds to the PSDs' dimensions is PixelXDimension and PixelYDimension. I can't use those variables because different file resolutions result in different pixel sizes. Is there anything else I can use?
Thanks!
Re: Sorting PSDs by file dimensions?
You can use Switch - Calculation in the variables pane. Top right you can create the calculation; this opens up one more variable pane in which you can combine Switch variables and fixed values in a formula using +,-,*,/,% (the percent is for modulo calculation) and brackets.
So in your case you will have to divide the pixel dimensions by the resolution and that is it. Note: I have seen cases where the resolution is not a straightforward number, but a calculation itself (a division), so to make sure the resolution calculation is done first, you will have to put that variable in between brackets.
