Switch Client custom filter based on metadata
I saw SWC 13 can allow custom filter and specifically metadata. But it seems the only value that can be used is yes/no and you can't even say what metadata you are up to.
Is there any chance you can sort jobs in SWC based on job's metadata ?
TIA
Loic
lombert
Re: Switch Client custom filter based on metadata
Post by lombert »
If i remember correct can't custom filter use metadata. If the metadata is in the "preview-window" then you can search for it.
Between jobs!
That's right indeed and unfortunately 2017 webportal won't allow it neither for now :\
pixelzooo
Post by pixelzooo »
I am currently developing a job overview with the current web portal. That is why I would like to ask about this topic again. I would like to display a specific value from the metadata in the job overview. In my tests, only a yes/no is displayed when I show the “Metadata” column.
So my question is: is it possible in version 25.7 to display specific metadata in the job overview of the web portal? Where can I select which field is displayed?
Thanks for any ideas.
Best regards,
Rupfi
Have you tried this app, it can help you with MEtadata that you will show in a check point or job boards.
https://www0.enfocus.com/en/appstore/pr ... h-job-info
And then you have this:
https://www.enfocus.com/manuals/UserGui ... anced.html
pixelzooo
Post by pixelzooo »
Hi jan_suhr,
OMG, thank you jan_suhr!
It's exactly what I was looking for and it works right away.
A thousand thanks for this tip.
With this module name (Refresh job info), I would never have guessed that this module also offers this function as a second option.
Thank you for this forum!
Best regards,
Pixelzooo
