Load information in Submit Point
dimadev
Post by dimadev »
i have a flow that starts whit a Submit Point. The Users upload file in Switch Client and insert info in the field.
I need to insert a Dropdown list menu in Submit Point where information is not always the same. Can i load a XML (or css, txt, xls, or any type) information in the Dropdown list menu?
In this Dropdown list i need insert a customer names. These change every day, but I can export these in any type of file.
Thx for your help.
Good day :)
PS: I not have a Database module.
Re: Load information in Submit Point
With the Database Module you could indeed populate the drop-down list from an ODBC data source. The only other alternative is the use of a script expression, for which you will need the Scripting Module. Here is a link to a similar case where the values of the drop-down list come from the list of files in a folder: viewtopic.php?f=13&t=1321&p=4555&hilit= ... oint#p4555
If you write the customer names into a text file the following script expression should do the trick (not tested):
var contents = File.read("path to text file");
var lines = contents.split(String.fromCharCode(10));	//10=line feed
lines;
Note that in a script expression you do not use "return someVariable;", but just "someVariable;"!
sander
Post by sander »
I would create a txt file or whatever with the entries.
Then create a list, this should get you started as it does the same with a directory listing;
viewtopic.php?t=1321
Edit: don't idle too long ;)
Edit2: Haha, we are even referring to the same topic :D
dimadev
Post by dimadev »
Hi, thx for reply.
I think not having the Scripting Module. I have a "Script Element"... but I think we do nothing with this :?
sander
Post by sander »
You don't have to use the scripting module but use a script expression.
I'm not 100% sure but I think the script expression is available without scripting module. Set your Data type to 'Dropdown list', now 'Define script expression' should be available:
