New job from existing file
patej
Post by patej »
Hi
I am trying to get the total page count of all files in a zip file and without using external scripts only way I know of is to use job.getVariableAsNumber("[Stats.NumberOfPages]"), but that requires that the files are turned into jobs, doesn't it? I tried to implement that idea, but I can't figure out how I can create a job from an existing file.
I tried creating a new job and copying the existing file into a path defined to it, but still I can't get the Stats.NumberOfPages out from the file, Switch only says "The requested statistics are not available for the job 'C:/Users/Switchuser/AppData/Roaming/Enfocus/Switch Server/temp/EnvironmentClass/2145/_0A1OR_dummyFileForNewJob.dat': the job does not exist" --> how can I get the statistics out from the pdf files through the job? Or am I trying a too complicated way to solve this?
Here is (one example of) what I've tried:
var file = job.getPath();
var unzipPath = job.createPathWithName( "unzipped", true );
var pageCount = 0;
if( !s.unarchive( file, unzipPath ) ){
	job.fail( "Failed to unarchive "+file );
	return;
else {
	var pdfDir = new Dir(unzipPath);
	var pdfFiles = pdfDir.entryList("*.pdf", Dir.Files, Dir.Name);
	for(var f=0;f<pdfFiles.length;f++){
		var tempJob = s.createNewJob();
		var filePath = tempJob.createPathWithName('pdfFile.pdf',false);
		s.copy(unzipPath+'/'+pdfFiles[f],filePath);
		pageCount += tempJob.getVariableAsNumber("[Stats.NumberOfPages]"); //this results in the error mentioned above
	s.log(2,'page count:'+pageCount);
Any help is much appreciated,
Patrik
Re: New job from existing file
The reason your approach does not work is because the job is only created when the script finishes. The solution is to use the FileStatistics class. You can use that on any file, it does not have to be a job:
var filestats = new FileStatistics(pathToFileAsString);
The rest is in the documentation of the class itself.
