Passing Parameters to an exposed com with vbscript
gbradley
Post by gbradley »
I'm looking for a way through scripting, send parameters to an exposed com with vbscript. The com is registered on the Switch server but not sure if there is a way to achieve this.
Is what we have thus far....
Function jobArrived(s, job)
custNum = s.getPropertyValue("custNum",job)
folderPath = job.getPath()
jsonName = s.getPropertyValue("jsonName",job)
x = Shell("E:\Switch Applications\OrderReceive\OrderReceiveSubmit\OrderReceiveSubmit.exe", folderPath, jsonName, custNum)
'objShell = CreateObject ("shell.exe")
'objShell.Run ("E:\Switch Applications\OrderReceive\OrderReceiveSubmit\OrderReceiveSubmit.exe, folderPath, jsonName, custNum")
OrderReceiveSubmit has only 3 parameters.
End Function
andrea mahoney
Re: Passing Parameters to an exposed com with vbscript
Post by andrea mahoney »
You can try using the Execute Command element and build the arguments using text with variables.
I have been successful using javascript to execute a command as well.
