Remove white objects but only one the background :\
I get a tricky one here. I need to remove white objects. That's fine so far.
It becomes trickier as I need to remove only the one in the background. Those that don't overlap any objects. The one overlapping anything should be preserved. I thought geomapper might help but can't see how.
Any ideas ?
TIA
Loic
Re: Remove white objects but only one the background :\
Post by abailescollins »
Geomapper should be able to help with the selection.
Can you send me the file Loic?
To clarify it's only background white objects, ie the ones that are overlapped that need to be removed?
The ones in the foreground stay.
Hi Andrew,
Sending you the file right away :)
Loic
Hi Andrew,
Loic
