104: Rendering images through PitStop Server not supported.
patrikje
Post by patrikje »
When trying to render images on OS X I will get this error. Why am I not able to render images? Is there any plugin or other requirements on the system that is hosting the server?
My next step is to move this to a windows based server and currently I get the same error there.
Re: 104: Rendering images through PitStop Server not supported.
It sounds like you're trying to use the "EnforceServer" ProcessingMethod. Try setting it to "EnforceInternal" instead. See Configuration XML file -
Initialize at http://www.enfocus.com/manuals/UserGuid ... /home.html
patrikje
Post by patrikje »
Thanks! That was the answer! Had an old config I used as a template with this option
