Imagemagick problem converting to CMYK
BartDenolf
Post by BartDenolf »
I have a flow where a Adobe RGB file needs to be converted to a CMYK file. I searched and tried everything and still imagemagick won't convert it to a cmyk file. By the way this is running on a Mac.
At this moment I used this argument:
"%1" +profile icm -profile "/Library/Application Support/Adobe/Color/Profiles/Recommended/AdobeRGB1998.icc" -intent Relative -black-point-compensation -profile "/Library/ColorSync/Profiles/ISOcoated_v2_300_eci.icc" "%2"
I almost tried everything but still it won't work. What am I doing wrong?
Bart
Re: Imagemagick problem converting to CMYK
Does the command you are using work in Terminal?
BartDenolf
No, and after some research it appears not all delegates have been installed so I'll have to update my Imagemagick before I can continue. Wasn't it for the tip to test it in terminal I wouldn't have noticed it.
Thanks!
Bart
