hello out there,
I'm facing a simple problem with a switch workflow – but can't find the solution! In the input hotfolder, several PDF files are processed. I need to split these PDF by their filename into uppercase and lowercase. See the screenshot for example. Do you have any idea to do this in a simple way?
Thank you in advance for further Information!
Beginner Question: sort Jobs by Case
- screen_job-splitter2.png (8.71 KiB) Viewed 6650 times
Re: Beginner Question: sort Jobs by Case
An easy one, use regular expressions
Hello loicaigon,
thank you very much! It works perfect!
Salut, Jürgen
Salut, Jürgen
