I'm thinking about splitting the flows up in smaller parts where at the end of one flow I put the file in a folder which also is the input folder for a different flow.
In this flow for instance I need to add a fourth option from the Bleed And Trim Set folder...
What I'm thinking to do is to put four output folders after Bleed And Trim Set and then have each of those folders be the input folder for a different flow. The same thing would be done for the Dismantled Job folder, but with three outputs. For the Body branch the output folder would then be the same folder as the Saddlestiched S output from the Bleed And Trim Set.
It's very important that the embedded xml data is preserved when moving the files back and forth between the different flows.
Will this work or will it only work as long as everything is done in the same flow?
