the PitStop Server is shut down when execute cli...
zldzk95
Post by zldzk95 »
We are implementing automation through our system and PitStop Server CLI.
However, when we run about 200 PDF files at the same time through the CLI in our system, the PitStop Server is shut down.
I wonder if there is a solution for this.
Please refer to the attached file.
Environment :
Hardware : AWS EC2 t2.xLarge Instance
OS : Windows_Server-2012-R2_RTM-Korean-64Bit-Base-2017.08.11 (ami-1d8d5573)
CUT.zip
(131.24 KiB) Downloaded 828 times
pitstopservercli.zip
(5.1 KiB) Downloaded 845 times
Re: the PitStop Server is shut down when execute cli...
Post by abailescollins »
I would suggest you contact Enfocus support for this one. support@enfocus.com
The cli is something most users don't have experience with, so they would be your best bet.
They can also dial in and look at your system if necessary.
