Script fails with Failed to make directory
cwswitch
Post by cwswitch »
Hi, we're not sure where this error lies, but seems to be a write permission. We have tried running with our network administrators account and with our switch account (which is already an administrator)
In all cases we receive the error
29/11/2017 8:45:24 AM,Error,SwitchScript1,test write,Script element,,,Error in line 16 of script : Error. Failed to make directory 'testtest'
	s.log(3,"jobArrived test write triggered");
	var dir = new Dir("C:\JOBS\J000029\Client\PDF");
	dir.mkdir("testtest");
// Is invoked at regular intervals regardless of whether a new job arrived or not.
// The interval can be modified with s.setTimerInterval().
	s.log(3,"timerFired test write triggered");
The script is attempting to write to the local disk as we thought the error was when we were trying to write to the job server, but the error still occurs when writing to our local C drive.
Paul Lewis
Re: Script fails with Failed to make directory
Post by Paul Lewis »
You need to escape / add double backslashes in your base folder object (which is "dir").
EG
var dir = new Dir("C:\\JOBS\\J000029\\Client\\PDF");
cwswitch
Post by cwswitch »
WooHooo
Thanks!
Incase anyone needs to know, you escape all backslashes, so
\\foo\bar
becomes
\\\\foo\\bar
A little known fact is that in many places Windows can handle forward slashes in paths. Instead of using "C:\\JOBS\\J000029\\Client\\PDF", try "C:/JOBS/J000029/Client/PDF".
This may not work everywhere, but often it does.
