I use metadata from a flow and then convert it to a simple tekst line (file) with an XSLT. I use simple text like "account number" en "page count".
	Is it possible to combine multiple of this lines together?
	I tried to do this by combining lines and then use "send an e-mail" but did'nt succeed.
						combine metadata to 1 file
 - TOP CONTRIBUTOR
I've used Javascript to create complex email messages before. It pulled from a text file, database, job metadata and stats to create the email body.
If you want to combine two files you could either call a program like 'cat' (MacOSX) or 'type' (Windows) which echo the contents of 1 or more files to stdout, or you could write a simple Javascript expression to read both files and generate a string variable.
