Switch 2017, LOGs almost 10gb !!
Posted: Thu Dec 07, 2017 10:35 pm
I am not sure if this is the right place to ask such a question as this relates to the actual setup and configuration of Switch itself. So please advise if this is not OK.
Today I found almost 10gb of logs in the following location:
C:\Users\Workflow\AppData\Roaming\Enfocus\Switch Server\logs
Switch preferences for logging are set for CSV files to be output to "C:/Users/Workflow/Documents/Switch Debug Log"
So what are the logs under the first path, which are regular text files and some are few hundred megabytes big, totalling almost 9GB !!!
There is also ServerLogs.db3 which is almost 10gb. What database is this and what data does it hold ?
Also it looks like those files are gaining weight incrementally, so are constantly in use and getting bigger, but are not purged or cleared.
I checked reference and configuration settings, but no word on these...
Could someone shine some light on this ?
