Flows not showing up in Switch
Northlander
Post by Northlander »
Im running Switch in a windows 10 environment. I started to get problems with the adobe configurators which did not trigg the actual applications. All jobs timed out. After some troubleshooting I saw that Switch Watchdog service wasn't running so I ran the watchdog-executable and added it to the startup folder. After that I restarted the server and now no flows are showing up inside Switch. Some of the flows I have exported, but the most recent ones that Im working with is not exported.
I have searched for the flows on the drive by entering ".sflow" but this don't get me any proper results. I also found some XML files which seems to be the flows but I have no idea how to import them into Switch.
I'm sorry if I may be unclear, but I'm having a little bit of panic right now
//Anders
Re: Flows not showing up in Switch
Sounds like a case for Enfocus Support.
The Switch Watchdog service should be always on. You probably have a corrupt database.
Northlander
jan_suhr wrote:Sounds like a case for Enfocus Support.
I´ve contacted the Support so Im waiting for a reply.
Do you know if there is some way to reload the XML-files which seem to contain the flows?
