Report Language not Available in SWITCH 17.1 (PitStop Element)
matt.baile
Post by matt.baile »
I just imported a flow into a SWITCH 17.1 install on a virtual server from an older physical box running SWITCH 11.5. I have a PitStop Server element asking for a Report Language, but when I try to select from Library, I have no options. On the older server, I have the option to select English, but not on the newer install. How do I get English to appear here as a selection?
Re: Report Language not Available in SWITCH 17.1 (PitStop Element)
Do you see any errors in the messages while you open the language dropdown or when you try to activate the flow?
Zoranj
Post by Zoranj »
I would try bringing in fresh Pitstop Server Configurator, it fixed similar issue for me.
If that does not fix it it, I would try reinstalling (repair option) Pitstop Server.
If that fails, call support.
