Check black file on elements that are not 100% black
printquest
Post by printquest »
I got files from a customer and it should be printed 100% black. I check every page with the pipet on elements that are not 100% black. How can I make a preflight that shows me pages that contains not 100% black elements (for instance 93.7% black).
And an actionrule that all not 100% black will be changed into 100% black.
It will save me a lot of time.
thanks in andvance!
Regards,
Bert
Re: Check black file on elements that are not 100% black
Is it sufficient to change the black in the fills and strokes of all paths or do you also want to change the color in images for example?
If it is sufficient to only work with fills and strokes, then you can use the "Remap color" action and add a rule to set a color range of 0-99% black to 100% black.
printquest
Padawan wrote:Is it sufficient to change the black in the fills and strokes of all paths or do you also want to change the color in images for example?
Yes, you are right. Thanks for the solution "Remap Color".
