Assign email address by script
major
Post by major »
Hello.
I'm looking for a script that would assign an email address to job.
I'v some jobs which I have to (after passing the flow) send by mail to different addresses according first three signs of input filename:
aaa_xxxx.pdf -> mail1@domain.org
aab_xxx.pdf -> mail2@domain.org
anything_else.pdf -> don't attach address
Best regards and Thanks for any response,
Major
Re: Assign email address by script
Depending on how many scenarios you have to dela with, you may achieve this out of a script with simple sorting.
However I agree a script is convenient.
Here is the script:
http://support.ozalto.com/downloads/Add ... Script.zip
And here some screenshots
major
Post by major »
Thank You very much.
It works, if I insert these, generated by script, private data to "To addresses" row in SendMail config.
Best Regards
Glad it helped. If it was me, I would have use an external data file that the script would load. That would allow you to increment the list out of switch.
Corporate films
Post by Corporate films »
You can also use this to assign email address by scripting in easy steps.
Corporate Film Makers
trafford
Post by trafford »
Thanks, loicaigon! It works!
