Access Stats.* in script
mclarke
Post by mclarke »
I'm trying to write my first script, which checks whether the NumberOfPages stat is divisible by four (4). I can't figure out how to get access to the stats of the file.
Does anyone have a sample script I could learn from that does the check? I was going tol use modulo and return a Boolean result.
Thanks in advance.
Re: Access Stats.* in script
mclarke
Post by mclarke »
Thanks, that was helpful.
allsystems
Post by allsystems »
var numberOfPages = job.getVariableAsNumber("[Stats.NumberOfPages]");
var modOperator = 4;//this is the number of pages you want to check
var modCheck = false;//set the check to false
if(numberOfPages%modOperator==0){
modCheck = true;
mclarke
Post by mclarke »
Thanks AllSystems. I will try that one out, also!
Post by gabrielp »
mclarke
Post by mclarke »
I'll check it out, thanks.
