Switch Inject
LasseThid
Switch Inject
Post by LasseThid »
Is it possible to inject all files with a certain ordernumber into a flow?
I.e. I send all pdf files for a job into a temporary archive. Then I merge all pdf files into one file that I send for approval. Once that file is approved I want to fetch the files from the temporary archive and inject them into the flow.
Re: Switch Inject
Yes it can be done, if the file has a marker, like the order number you can in a few different ways inject them or hold them until something triggers a release of them.
LasseThid
Re: Switch Inject
Post by LasseThid »
All incoming files are sent from a Submit point and are renamed adding the order number in front of the original file name.
So I should be ok then.
Thanks.
