Post an XML file using SOAP
apietrocini
Post by apietrocini »
I have an xml file that contains order information... Is there an easy way to post that order to a web service that is SOAP based and not REST... My thought was that I could use the HTTP request, but if I understand correctly that is a REST based web service...?
Thanks,
Anthony
Re: Post an XML file using SOAP
Post by dkelly »
Here's a SOAP example
	// create soap request
	var theRequest = {
	    "http://www.webserviceX.NET/:ConvertTemp" : {
	        "http://www.webserviceX.NET/:Temperature" : 100.0,
			"http://www.webserviceX.NET/:FromUnit" : "degreeCelsius",
			"http://www.webserviceX.NET/:ToUnit" : "degreeFahrenheit"
	var SOAPRequest = new SOAP(theRequest);
	SOAPRequest.writeToFile("/tmp/request.env");
	var SOAPResponse = SOAPRequest.requestMessage("http://www.webserviceX.NET/ConvertTemperature.asmx", "http://www.webserviceX.NET/ConvertTemp");
	SOAPResponse.writeToFile("/tmp/response.env");
	var values = SOAPResponse.parseBody("//dn:ConvertTempResult");
	for (var i=0; i<values.length; i++) {
		s.log(1, "value = " + values[i]);
