Support for a versioning system like GIT?
tz8
Post by tz8 »
Hey all,
did anyone find a way to use GIT to track changes on flows? Or is there at least a common usage to export flows and check them into a versioning system?
How do you do it?
Cheers,
Thorsten
Post by dkelly »
The flows and properties are all stored in XML format. You could create a git repository in the directory that Switch uses to store them, eg. ~/Library/Application Support/Enfocus/Switch Server on Mac.
Scripts are a little more complicated because they are stored in a ZIP package. Git would track changes but you can't easily diff revisions.
tz8
Post by tz8 »
Thanks a bunch, that helped a lot! For the scripts i'll just let the Developer copy/paste the Javascript into Eclipse and do the commit from there
