Calculate media usage
Terkelsen
Post by Terkelsen »
I'm trying to calculate the total media usage for several PDF-files. I'm using the calculation feature to calculate the total area of a single PDF (with multiple pages). I do that this way:
[Switch.Calculation:Expression="([Stats.MediaBoxHeight:Type="Defined"]*0.035278)*([Stats.MediaBoxWidth:Type="Defined"]*0.035278)*[Stats.NumberOfPages]",Precision="2"]
This returns the result in square centimeters. I store the result in Private Data. Is there any way to calculate the sum of this number for all PDF's contained in a folder (apart from merging the files before doing the calculation).
Re: Calculate media usage
I believe this should be possible via scripting, I don't think it is possible without.
Terkelsen
Post by Terkelsen »
Thanks Padawan. I'll try to post the same question in the scripting section.
ldewilde
Post by ldewilde »
Hello Terkelsen,
There is a new Counter app that does the job:
https://www.enfocus.com/en/appstore/product/counter
Laurent De Wilde
Xerox BeLux
