PDFtk burst
abonsey
PDFtk burst
Post by abonsey »
Hi All,
I use PDFtk for a lot of flows so I know it works within Switch fine.
I'm trying to burst a PDF to multiple single PDFs but I can't get it to work. If I use the standard burst command I just get the last page:
"%1" burst output "%2"
File at Path
I tried adding _page_%04d but it just errors.
How can I get all the pages burst and not just the last one?
TIA
Andrew
Re: PDFtk burst
Why not use Switch's own built in Split PDF tool?
abonsey
Re: PDFtk burst
Post by abonsey »
The PDF files are made using PDFsharp.
Some work and some don't.... I just don't get any split pages ie all or nothing. SO I'm trying PDFtk to see if that will work with these files from the client.
Andrew
Re: PDFtk burst
Sounds like a bad PDF
abonsey
Re: PDFtk burst
Post by abonsey »
They view and print fine. Just can't split them that's why I want to know how to do it with the burst command.
Have you got it to work with PDFtk?
Andrew
Re: PDFtk burst
Yes but they were made in InDesign
