Sort images by landscape or square
tarek.bettaieb
Post by tarek.bettaieb »
Hello guys,
I need your help!
I'm trying to create a flow in Switch for images.
The idea is to sort images by landscape or square, and I'll made some rescale...
I tried with different script but no luck :( javascript, expression etc....
Any idea how to do this?
Thank you
Tarek
Terkelsen
Re: Sort images by landscape or square
Post by Terkelsen »
You don't need any scripting to sort the files. Use the Switch variables. An image will contain exif metadata. It will tell you the exif:PixelXDimension and exif:PixelYDimension. If exif:PixelYDimension is greater than exif:PixelXDimension the image is landscape. If it's the opposite it's portrait and if they are equal it's square.
